It is currently Tue Jun 24, 2025 9:32 am
PostPosted: Sun Apr 23, 2006 11:13 am
anyone have any ubiquitous drill press jigs pictures to share? I want to upgrade my (radial) drill press drilling operations!
I'm thinking of the table with adjustable fence/clamping
Also improvements/additions for making a luthier's friend type fixture/jig
Also any vac setup suggestions. Mine work well, but let's see what folks are doing!
TIATerry Stowell38830.8436921296
PostPosted: Mon Apr 24, 2006 12:16 am
bump
PostPosted: Mon Apr 24, 2006 3:41 am
Hey Terry, in the meantime, how' the inlay project coming along?
PostPosted: Mon Apr 24, 2006 4:11 am
Terry, I use my drill press for a lot of functions, even drilling! Although I still like using a hand plane a lot of my thicknessing takes place using the safety planer and drill press sander, especially neck thicknessing. I use it as a spindle sanding set up, both with the large drum and with the robosander fro fine copy work. With the table router and band saw it is the most used tool in my shop.
PostPosted: Mon Apr 24, 2006 7:24 am
Collin, I am about to make a couple of the sanding disk you use. From the image above, it looks like you relieve the outer edged of your disk, is this just an optical illusion, a slight arris, or an extended curve of the lip if that makes sense?
Cheers Kim
PostPosted: Mon Apr 24, 2006 1:54 pm
Hey Colin, How do you like the functionality of that drum? What weight paper do you use? What are the pros and cons of that type drum (Standard paper sure is a plus!)
Thanks for the pic
PostPosted: Mon Apr 24, 2006 1:58 pm
Hey Serge,
I'm still trying hoping to get and Adirondack top for the project (That's where I was raised...)
I may need to resort to an Englemann top I have on hand. I just wanted to make it out of woods ofund in our own back yard. Anyhow, I haven't started the inlay yet. I'll definitely keep you posted though.
PostPosted: Mon Apr 24, 2006 3:04 pm
Thanks Terry,
It would sure be nice to get that adi top you're hoping to get, good luck with finding it!
I'll stay tuned for that project!
PostPosted: Mon Apr 24, 2006 7:40 pm
Kim, yes there is a slight angle on the edges of the disk, just helps with the infeed of timber, I sand down to 1mm thick using this and you don't want thin timber hanging up on an edge. I just use two layers of 19mm ply the top one drilled right through and the bottom one just relieved for the internal nut and washers. Insert and tighten the bolt and it's nuts then glue together. Stick self adhesive velcro hooks to the bottom and your ready. I have a number of them ready made up with different grits.
Terry, I love the big bobbin sander, It's got a cam lock for changing the loading. I cut up the heavy cloth backed abrasives made for a belt sander and they give a good length of service if cleaned regularly with the rubber belt cleaner. I use 80, 120 or 180 grits according to the job.
ColinColin S38832.2248842593
PostPosted: Mon Apr 24, 2006 7:55 pm
Thanks for that Colin, I have some 6" disk made just as you have described earlier but was wondering about the reliability of the self adhesive backing on the velcro hook pads.
Do you seal your ply with anything after you level sand the bottom of the disk on the drill press table, or do you just blow them off and stick them straight to the sanded ply?
TIA
PostPosted: Mon Apr 24, 2006 8:22 pm
Kim, as you say, I sand the disc flat using the table, like this:
Then just wipe it clean and add the self adhesive velcro hooks, I get it in 6" wide rolls. It has never even looked as if it would come loose.
PostPosted: Mon Apr 24, 2006 8:55 pm
Thanks again Colin, where do you buy 6" wide rolls? The only stuff I can find locally is a pre-cut 6" disk with 6 disk of paper in 3 grades. It's called a velcro starter kit and is murderer at +$20.00 au for a kit
Cheers mate and once again TIA
PostPosted: Mon Apr 24, 2006 9:54 pm
I see on your bobbin sander a groove where you push and insert your cloth backed abrasives, do you also glue the abrasive to the bobbin cylinder or that groove or recess is enouh to keep the abrasive on the bobbin ?
i hope my question is well formulated here
Thanks for the great tips and TIA for this one!
SergeSerge Poirier38832.2886689815
PostPosted: Tue Apr 25, 2006 12:10 am
Serge, the bobbin has a hole bored down it, that the abrasive is pushed into, an oval rod is pushed down and twisted to lock the abrasive in place.
Terry, I don't need to tell you that it's important to level the table precisely with a bent wire in the chuck before sanding the disc flat.
Kim, I bought the velcro from Axminster here in the UK in 1m long rolls. They only seem to have 115mm wide now.
Velcro rolls
PostPosted: Tue Apr 25, 2006 12:23 am
Thank you very much Colin, i have purchased a 2" diameter sleeve from our Canadian Tire store and have a slightly less than 2" dia wood dowel that is slack a bit so your idea comes at the right time!
Thanks again Colin!
PostPosted: Tue Apr 25, 2006 12:56 am
Thanks Colin, boy that stuff is hard to find in a 6" roll the 115mm is as close as I have seen in a long search.
cron
